Assembly Posted March 2, 2009 Share Posted March 2, 2009 On testing my text size control object is not working on insert. The text is defaulting to being sized in relation to the layer it is inserted on. On editing the PIO it works perfect. I think I read somewhere that PIO's don't get a layer handle until after they have been insert. If so this would explain the behavior, as my calling getlayer will be NIL until after it has completed the insert... is there a way around this?. Quote Link to comment
Assembly Posted March 2, 2009 Author Share Posted March 2, 2009 When this tool is inserted into layers larger than 1-10 the text looks bad. I used to include a If layerscale<10 THEN textprocedure. I have revised the tool using the textPIO code in last post to sets the text to be 3mm for ViewPort scales 1-5. BUT, as above, when inserting it inserts the text is too big again. To work around this I included if IsNewCustomObject(pioHandle)=False Then TextProcedure. _____________________ PROCEDURE SECTIONFRAMING; Var layerhandle, pioHandle, pioRecordHandle, PioWallHandle: Handle; PIOlayerscale:Integer; pioName: String; text:boolean; Radius: Real; width: Integer; Depth: Integer; BEGIN; pushattrs; Nameclass('Section-Framing'); If (getcustomobjectinfo(pioName,pioHandle,pioRecordHandle,PioWallHandle)=True) THEN BEGIN; width:=pframewidth; depth:=pframedepth; layerhandle:=getlayer(pioHandle); PIOlayerscale:=getlscale(layerhandle); RRect(0,0,width,depth,5,5); setclass(lnewobj,'Section-Framing'); radius:=1; Moveto(radius,radius);Lineto(width-radius,depth-radius); setclass(lnewobj,'Section-Framing'); setlw(lnewobj,2); IF (plength='Continious') THEN BEGIN; Moveto(radius,depth-radius); Lineto(width-radius,radius); setlw(lnewobj,2); setclass(lnewobj,'Section-Framing');; END; {----TEXT------------------------------} text:= ptext; IF(text=true) THEN IF IsNewCustomObject(pioName)=False THEN BEGIN; textsize(5*5/PIOlayerscale); TextFont(GetFontID('Arial')); TextFace([]); TextFlip(0); TextRotate(0); TextSpace(2); TextJust(2); TextVerticalAlign(5); TextOrigin(width/2,0); BEGINTEXT; num2str(0,width) ENDTEXT; SetTextWidth(LNewObj,width); SetTextSize(lnewobj,0,50,5*5/PIOlayerscale); Setfpat(lnewobj,0); TextRotate(90); TextOrigin(width,depth/2); BEGINTEXT; num2str(0,depth) ENDTEXT; SetTextWidth(LNewObj,depth); Setfpat(lnewobj,0); END; END; popattrs; resetobject(piohandle); END; Run (SECTIONFRAMING); Quote Link to comment
