Doors are closed on floorplan
cameleyes
Hi,
I'm sure this is quite a simple issue for anyone with experience but I have a room plan with a pair of doors inserted correctly with wall breaks. I recall seeing the doors in the open position but now somehow they have changed to closed.
Do you know how I can open them again?
Thanks. Matt
Just to help you out:
In top/plan the doors will always be open. You are seeing the 2D representation.
In all other views, which are 3D, the doors will be open or closed based on your selection. It you look at the Object Info palette, you will find a checkbox marked Show 3D Open. This option is also available in the Door settings dialog under the View tab.
If you really want to see the door closed in Top/Plan, you can set the Angle value that is right underneath Show 3D Open to 0.
Edited by Judah Warshaw
