Kris Posted January 7, 2009 Share Posted January 7, 2009 I am wondering if there is a way to have alternate units in my dimensions. I have a file that I would like to keep in meters, but change just the dimensions to millimeters. Is this possible? Or, can I change just one viewport to millimeters? Thanks! Kris Quote Link to comment
Pat Stanford Posted January 7, 2009 Share Posted January 7, 2009 In the File Menu:Document Settings, Check out the Document Preferences, Dimension tab, Dimension Standards. The ASME Side By Side and ASME Stacked will let you show both the primary and secondary dimensions at the same time. You can create your own dimension standard that will only show the secondary dimensions. The units for the dimensions are set in File:Docuemnet Settings:Units. Quote Link to comment
Kris Posted January 7, 2009 Author Share Posted January 7, 2009 Nice! Thanks for the tips! Quote Link to comment
