treythefarmer Posted December 2, 2008 Share Posted December 2, 2008 Hi all, When I make elevations (via section viewports)through any walls or objects they show up with arrowheads in them. The line weights and everything are fine and this hasn't occurred with other viewports created previously. I have been converting the viewports to lines and fixing them up manually, and when I do the lines for the walls have the arrow head box checked, which is a simple fix. The issue then becomes (other than the nagging of knowing this is a poor fix), that all of the annotations within the viewport disappear. This has given me two questions. First, why has this sudden take over of arrowheads occured and is there any way to fix it properly? Second, when I do convert a viewport to lines, is there any way of keeping the annotations and converting them along with it? Thanks for your help! Trey Quote Link to comment
Bob Holtzmann Posted December 2, 2008 Share Posted December 2, 2008 My first guess on the arrowheads suddenly appearing is that the class the lines are on has arrowheads set for "Use on Creation", and/or the arrow buttons are depressed on the Attributes Palette. Quote Link to comment
