VW09 CRASHES ON OPENING OF SAVED FILE
I create a new file from a blank document.
I draw my model, add sheets and viewports, import pdf's, create my desired VP and sheet layouts. Save the file locally. Close VW09. Reopen VW09 and then select the file I had just closed and it crashes.
I look at the saved location and a new file is created with an extension *.lck. Which I presume is a locked file. I open it using notepad and this is what it says...
<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
Jason Christensen
OFFICE-PC
3308555123
Does not seem to help me but maybe someone else understands what this is about.
Anyone else with a similar issue?
Edited by j.christ
