Colin Posted May 8, 2008 Share Posted May 8, 2008 Hi, I have a site model of current topography, and a second model of proposed final topography. How do I get a cut and fill volumes between these two surfaces? I think I have to create a proposed surface in the original model, but I am not sure how to use the polylines I have for desired final contours as a site modifier. Any suggestions would be greatly appreciated. Thanks. Quote Link to comment
gScott Posted May 8, 2008 Share Posted May 8, 2008 you need to make one DTM of the existing site. then you need to make 'site modifiers' which represent the proposed levels, these can either be done by using the 'site modifiers' tool, or drawing shapes + 'create objects from polyline' to make 'site modifiers', 'pad' type. you then give the pads heights and make sure that all pads are enclosed by a 'fence' site modifier won't work properly> in addition, pads shouldn't touch each other, even a few mm apart will do; and pads shouldn't touch or overlap the fence... now select the DTM , change the display to 'proposed' and 'update' if you haven't made any mistakes it should reflect the proposed landscape + the object info should tell you the cut + fill data between proposed + existing. whether the numbers bear any correlation to reality is another story + posts here suggest not. if you are using 12.5 and you don't have the 'site modifiers' option in 'create objects from polyline' then read the link if you want to fix it... http://techboard.vectorworks.net/ubbthreads/ubbthreads.php?ubb=showflat&Main=16918&Number=75868#Post75865 also try the manual + the help Quote Link to comment
