Jodyb17 Posted May 7, 2008 Share Posted May 7, 2008 (edited) Is there a way to do this in viewport annotations? right now I have to draw lines on the walls for the angular dimension tool to work. Edited May 7, 2008 by Jodyb17 Quote Link to comment
Jodyb17 Posted May 8, 2008 Author Share Posted May 8, 2008 Nobody? Sometimes this causes a VW crash on my machine.... Quote Link to comment
Jeffrey W Ouellette Posted May 9, 2008 Share Posted May 9, 2008 Jody, In VW12, this should work without drawing extra lines in the annotation space of the VP, although not as well as in VW2008, but it is possible. With the Angular Dimension tool selected, at the top of the window, in the mode bar should be three small "mode" icons. select the third, last one on the right. It is the reference line mode. Trace the lines/edges/objects you wish to dimension; drawing "virtual" lines for each edge. No need for the extra step of extra lines. If you want more, gotta upgrade... Quote Link to comment
