AustinDesignInc
Open GL Texture "Checkerboard"
Often when I edit a texture and then view it in Open GL it turns into a checker board of tiny repetitions of the texture with white space in between them.
The weird thing is that it doesn't always happen. I have been using the same clapboard siding texture for a long time and changing the color as needed, but today when I tried to make green clapboards with the same texture I got a green checkerboard.
If I render the same texture in Renderworks mode it looks fine. Is there a Vectorworks preference setting that would affect Open GL rendering in this way? Simply changing the quality in Open GL options doesn't seem to make a difference.
There are two files attached with samples of the normal and checkerboard textures.
