Split, Add Surface and several other tools modify polyline curves by adding straight segments between the curves. Sometimes many straight segments. These apparently connect non coincident tangents which were not revealed duringl poly creation or vertex edits. The resulting, many faceted curves are difficult to edit.
My wish: The poly vertices would only be modified/added in a "zone of influence" near the split or addition. And/Or some way to filter out the excess points. Similar to VectorBits Purge Poly (apparently only available for VW2008)
Benson Shaw
-B
0 answers to this question
