markdd Posted April 2, 2008 Share Posted April 2, 2008 I have entered my symbols as usual and attached label legends and all is as I expect. However!..... I want to change the Y rotation of the symbol to 180? so that the fixture appears as it would when on a floor-stand. No problem. But the symbol now obscures some of the info in the label legend. Is this an oversight on NNA's part or is there a simple fix, or as I suspect, I will have to generate a new symbol with the 3d geometry already fixed. Any thoughts would be terrific! Thanks Mark Quote Link to comment
David Roy Posted April 13, 2008 Share Posted April 13, 2008 Can you make a different label legend that spaces out the information so it doesn't get obscured? Will enabling or disabling "right reading" help? Also, don't forget that inside the label legend you can position labels, rotate them, move them forward and backward, just like the rest of the drawing. I'm a bit confused about what symbol you are looking for - is it basically a section of a normal instrument? Quote Link to comment
