Hatches are a great thing, with a little bit creativity, you can make wonderful things with it.
But it's quite a time-consuming way to make or edit them. Therefor, remove that Hatches Dialog out of VW and let us edit hatches like we can edit all object in VW: in model space (right translation? :crazy: ).
That way we can use the tools that we are use to work with, like move, rotate, rescale, zoom in, zoom out, giving attributes with attributes palet, using the pipet (eyedropper?)....
That way, you can select all the lines of the hatch, rotate them, and in less then a second your hatch is rotated.
Also, that way you can put every line in a separate class. if you need high details, you can set all those classes visible, if not, you can just set the class of some basic lines visible.
And you can change the color of the lines of your hatch in your viewport. Changing from color to greyscale is possible then, even for your hatches!
Also, it would be cool if we could ad other object then lines to a hatch. Object like rectangles, arcs, poly's, text,...
maarten.
1 answer to this question
