squirrely scroll wheel
I'm curious if anyone else has encountered this...
I use VW on two displays - the left is an external, the right my laptop. I typically have the main drawing window on the left (external) display and the OIP and resource window on the right.
For the last couple of days in the drawing window my mouse scroll wheel only zooms in and out intermittently. I can pan around a bit and then the mouse wheel may start working again.
If I move the main window to the right (laptop) display then it works great.
The scroll wheel works in other programs on the left (ext) display.
I don't believe I've changed any settings...
I tried a spare mouse - same thing.
Any ideas... I use the mouse wheel a lot.
Thanks
-rob
Guest Donne Martin
Rob,
I'm pretty sure this bug was fixed in a previous service pack. Please update to SP2.
The problem only occurred if you had your external to the left of the main display, but not to the right.
Donne
