JohnGib Posted March 17, 2008 Share Posted March 17, 2008 (edited) Using VW 08 on XP pro sp2. And have discovered that the "save as" command saves the drawing and then proceeds to exit the VW application. No warnings or errors just a normal close. I should add that the "save as" is the only save option that causes this problem. New info: The "save as" is pointed to a USB flash drive. Still a problem but not a big deal to save to the root then copy to the flash drive. Thanks Edited March 17, 2008 by JohnGib Quote Link to comment
