Joz Posted March 11, 2008 Share Posted March 11, 2008 (edited) so.... I've got a drawing border object that I created some time ago. It's been working fine since September or so. I used it in a new file today, and all the colors are gone. VW Preferences are not set to B&W only. When I edit the symbol, the colors appear in the OIP as tho the object were, in fact, in those colors... they just don't appear. Filled rectangles are white, lines are black, and neither of them are orange like they're supposed to be. The only other place I know to set things to B&W is the viewports, which are set that way but shouldn't affect the tb/db? Thanks. -J Edited March 12, 2008 by Robert Anderson Quote Link to comment
Pat Stanford Posted March 11, 2008 Share Posted March 11, 2008 Check the Document Preferences. Make sure the B&W Only is not selected and also make sure that Layer Colors is not selected. Pat 1 Quote Link to comment
Joz Posted March 11, 2008 Author Share Posted March 11, 2008 Aha... was layer colors. Thanks very much. Quote Link to comment
Vectorworks drafter Shiv Posted March 2, 2023 Share Posted March 2, 2023 how can we set color logo on black and white sheet Quote Link to comment
Pat Stanford Posted March 2, 2023 Share Posted March 2, 2023 You can't. If you set the sheet to black and white then everything will be in Black/White. The work around if you are using Viewports is to set the Layer to use colors and then set the viewports to be Black & White using the check box in the Advanced Properties from the OIP. Quote Link to comment
