NigelShaw Posted February 21, 2008 Share Posted February 21, 2008 Hi, i have set up a custom title block and that works fine and is inserted into the correct position. however, i have a few queries- 1. can the border settings be adjusted as a default? they currently come in at 12.7 for all sides with a grid enabled and i find it quite consuming turning all of this off for every page. 2. how do you insert the revision data that you can add from the border settings? i can add revision data in the settings but it does not appear on the drawing.i am using fundementals 2008 with renderworks and service pk 1. many thanks, Nigel Quote Link to comment
