Bart Rammeloo Posted August 8, 2003 Share Posted August 8, 2003 When I try to combine the following two nurbs surfaces into one, nothing happens: It works with other configurations like curved surfaces, but not with this one. I can't use the connect tool on this one either. Any reason? Kind regards, BaRa Quote Link to comment
Vectorworks, Inc Employee Biplab Posted August 8, 2003 Vectorworks, Inc Employee Share Posted August 8, 2003 I think you cannot combine discontinuous surfaces (sharp corner between surfaces in your picture) using the connect/combine tool. Quote Link to comment
Bart Rammeloo Posted August 8, 2003 Author Share Posted August 8, 2003 I think you can combine them, but not with that tool. Take a look at the following movie: dual object combine However, this should also work when the edges are adjacent or overlapping. Right now, I have to move the U's or the V's of the top edge to get a straight angle again. Cheers, BaRa [ 08-08-2003, 08:51 AM: Message edited by: BaRa ] Quote Link to comment
Kong Posted August 9, 2003 Share Posted August 9, 2003 this cause use a Add Solid.. Command for together to One Object (but not one surface). then it will use other tools/Commands or must move a some Surface for space (Between), then you will can use the connect/combine tool.(this ask is not you want) or use Extact Curve tool for create Curve follow Outline Surface, then use the Create from Curves command., but get to unplane surface. (i can't Downloan .Mov file) Quote Link to comment
Bart Rammeloo Posted August 10, 2003 Author Share Posted August 10, 2003 Kong, I don't have a problem constructing that shape, but I do have a problem with the fact that the combine command doesn't work in this case. I can find no logical reason for this. Biplab said you probably cannot combine discontinous surfaces, but the Connect and Combine tool (in the 2D-pallette) does exactly that. At least, that's what the movie shows. So my guess is there's something wrong with implemention of the combine command. And about the movie: I can download it without any problem, even after clearing my cache. Thanks for replying Kind regards, BaRa Quote Link to comment
