Developer Wiki and Function Reference Links Read more... ×
Heath
Select all occurrences of a symbol.
I am sure this is simple for those of you here much smarter than I. I would like to have a tool (script) that I can select a symbol and have all of occurrences on the active layer of that symbol selected. I know I can use the custom selection tool, but I would sure like to just click on one of the symbols and have all occurrences selected without having to fill out all the custom search criteria.
Thanks in advance for any help given.
Heath
Heath,
See if this works for you:
Procedure SelectLikeSymbols;
{User clicks on symbol in drawing and selects all like symbols}
{Works on individual and symbols inserted in walls}
{? 2008, Coviana, Inc - Pat Stanford pat@coviana.com}
{Licensed under the GNU Lesser General Public License}
var H1,H2 :Handle;
B1 :Boolean;
X1,Y1 :Real;
N1 ,N2 :Integer;
S1 ,S2 :String;
Begin
{Gets the user click on an object}
B1:=False;
While Not B1 do
Begin
GetPt(X1,Y1);
B1:=GetPickObjectInfo(X1,Y1,H1,H2,N1);
End;
{end of Gets the user click}
{Handle the click}
If H2 <> Nil then H1:=H2;
N2:=GetType(H1);
If N2 = 15 then {If object is not a symbol don't do anything}
Begin
S1:=GetSymName(H1);
DSelectAll;
S2:=concat('S=',chr(39),S1,chr(39)); {CHR(39) is single quote}
SelectObj(S2);
End;
RedrawAll;
End;
Run(SelectLikeSymbols);
Pat
Heath,
I just noticed that you only wanted the objects on the current layer.
Replace the S2:= line with the following:
S2:=concat('(L=',Chr(39),GetLName(ActLayer),Chr(39),') & (S=',chr(39),S1,chr(39),')');
As an aside, if you have your layer options set to Show/Snap/Modify others, you can click on a symbol on a different layer and get all the symbols on the active layer selected.
Pat
Pat,
Thanks for your expertise on this. It does exactly what I wanted.
Heath
