graham75 Posted January 22, 2008 Share Posted January 22, 2008 I'm still relatively new to VW, but I've been modeling in Form-Z for a long time... is there an easy way to bend a solid object in VW? For example, I want to extrude a cylinder and then bend it in half. I know I can draw a path and extrude a shape around it, but is there a specific tool for rolling/bending solid objects? Quote Link to comment
islandmon Posted January 23, 2008 Share Posted January 23, 2008 SolidObjects are formed from primary geometries like 2d shapes & NURBS Profiles & Paths. Modification of a SolidObject requires modification of the underlying geometry or changing the surface & polygon mesh control points . Usually it's far easier to edit the basic geometry. Avoid messing with the mesh is my motto ; ) Quote Link to comment
graham75 Posted January 23, 2008 Author Share Posted January 23, 2008 but what if you have a complex 3D shape that you need bent... for example, let's say you've got a 1/4" extruded trapezoid that you need bent in half on a 60 degree angle (I'm staring at the "foot" of my mac monitor right now)... how would you go about making that shape? In other 3D programs, I can make the shape as a flat extruded object, do all my corner and edge filleting, then bend it. Is that not possible in VW? It seems to me that my only option in VW is to do a series of solid subtracting using other shapes like chiseling away a piece of marble. Quote Link to comment
islandmon Posted January 24, 2008 Share Posted January 24, 2008 >3dExtrudeObject>Edit ( enter Group )>2dPolygonObject>use Polygon ReShape Tool>select vertices to be repositioned>move vertices as required>exit 2dPolygon>new 3d ExtrudeObject Quote Link to comment
