Clocco Posted January 18, 2008 Share Posted January 18, 2008 Hola to everyone,i have an other question for you: I have to create a 3d model of a siteplan and i have all terrain curves with z values but with the terrain tool vectorworks crash,can you help me? thanks... Quote Link to comment
Benson Shaw Posted January 19, 2008 Share Posted January 19, 2008 Hi, Clocco - Make sure that you are only selecting the contours. Anything other than a 3d poly or 3d locus could cause a failed command or a crash. One or more of your contours might be corrupt or incomplete or something. Try selecting two of the contours and making a DTM from that. If it works, try with about half of them. If that works, try the other half. If you find some bad ones (stacked vertices? gaps or hidden segments? height label in the line? etc), trace and replace, decompose/recompose, or do an edit to see if you can fix it. Tracing is usually the fastest way. Use 2d polyline in spline mode, convert to 3d poly, set z value. Delete the old one. It would be helpful if you edit your forum profile and add info about your VW version and system. Hope this helps! -B Quote Link to comment
