rsa Posted December 6, 2007 Share Posted December 6, 2007 I have a file where - when I do a batch pdf export with the option to create a separate files for each sheet checked VW will open the box at the bottom of the screen and seem to go through the process of exporting every sheet, but will not export 6 of the 12 sheets. If I do the process as one file it works fine. I can't identify any difference in the sheets that work and those that do not. Has anyone had a problem like this? I'd like to fix it because I use this option a lot. thanks Rob Quote Link to comment
