Kimcz
SP1 2008
I have tried to install SP1 2008 without success. I get to 88% install. It then says installing 1 of 2. The time line goes to about 1/3rd way, then stops. The install tablet then says 89% install. But the whole install procedure has hung. I have tried this several times, with new downloads. Always the same result. Any suggestions? Katie? Does anybody have the same problems?
New computer. PC Dual quad, so there should be no problem. XP
I find that it takes a long time to install VW these days because of the automated update feature. The install program is contacting an NNA server and downloading updated files.
You can choose not to do this.
The truth of it is that VW is becoming a bigger application each version. The library files is the largest contributor to the size of the application.
Thanks for the replies. I have waited over half an hour for anything further to happen. I will try for longer and see what happens then.
Patience may be in order here. If you wait more than an hour, I'd say redownload the updater and run it again.
