cdailey 0 Posted June 15, 2000 Me again...(VW newbie) When importing a DXF file for the first time in VW, a dialog box appears for setting up text font translation. Is there a way to get back to this dialog box? Thanks. Craig Quote Share this post Link to post
Guest Posted June 17, 2000 Craig, Unfortunately as with the Mapping line weights to colors, you will no be able to go back to this window once you have finished the import process. The easiest way of changing the text on a large scale will probably be the custom selection command in the program. Quote Share this post Link to post
Guest Posted August 3, 2001 DXF import uses the normal VW font mapping system, so you can go to VW Preferences -> Display -> Edit Font Mappings to change existing mappings. Quote Share this post Link to post
