jfitch Posted October 23, 2007 Share Posted October 23, 2007 I have problems when I edit polylines in drawings created in VW12 and before. Not all polylines, but some of them. Is this a known bug? An example is enclosed. Double click on the polyline to enter editing mode. Then click on the center handle of the bottom line. As soon as you click on it, the upper left corner arc vertex shifts to the right. And it stays there if you do any editing or not. You can move the corner vertices at the ends of the bottom line, no problem. But if you move it by its center, problems. Many polylines don't exhibit this behavior, some do. I have not been able to narrow it further. Intel Mac, 10.4.10, VW2008 SP1. Quote Link to comment
jfitch Posted October 28, 2007 Author Share Posted October 28, 2007 Do I guess by the silence that no one can verify? Or that it is a known problem? Quote Link to comment
jbrhwy Posted October 28, 2007 Share Posted October 28, 2007 Your file 375-test4.vwx can no longer be downloaded, but I had looked at your file & thought I had responded. I have been reporting a problem with polylines for years where the automatic midpoint between arc vertexes will reduce the radius if the end point of 1 of the arcs is greater than one half of the tangent distance between the vertexes. The work around is to place an additional corner vertex on the line between the vertexes, but be prepared for a tonne (ton) of fun with reversing curves. Quote Link to comment
jfitch Posted October 29, 2007 Author Share Posted October 29, 2007 I will post the file again. I am aware of the "feature" you are talking about and have learned to live with it. I don't think this is the same thing: it already has a corner vertex between the line being edited and the corner radius. The corner does not change radius, it moves. Quote Link to comment
jfitch Posted October 29, 2007 Author Share Posted October 29, 2007 Funny, I just uploaded it again and when I try to download it to check, I get an error 404. Bug in the bulletin board? Quote Link to comment
Guest Posted October 29, 2007 Share Posted October 29, 2007 I'm looking into the 404 error. Please send the file along with a description of the problem to both tech@nemetschek.net and bugsubmit@nemetschek.net. Please be sure to include version of VW, computer OS specs, and a detailed description of the problem. Add the last 6 digits of your serial number, too, to speed up the process. Quote Link to comment
Guest Posted October 29, 2007 Share Posted October 29, 2007 404 error is resolved. Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted November 1, 2007 Vectorworks, Inc Employee Share Posted November 1, 2007 jfitch, this is definitely a bug. The reshape routine is apparently trying to make "almost-tangent" edges tangent when in reshape. Have you sent this to bugsubmit? If not please do so. Thanks very much! Quote Link to comment
