Adjust Flipped Text
digitalcarbon
most of my work is architectual so i want to have "Adjust Flipped Text" on all the time.
however, i do get projects were i do not want "Adjust flipped Text" on. such as road names. see attached. there should be an file independant "No Adjust Flipped Text" only for that file. i am afraid that all this flipping will screw up some of my architectural work.
Edited by digitalmechanics
2 answers to this question
I don't understand the problem, digital. It sounds equivalent to suggesting that some files should draw arcs by radius, and other files should draw arcs by three points. Wouldn't you rather have both capabilities in all files?
And similarly, wouldn't you rather have the choice in all files either to automatically adjust a text while rotating it so that it reads from below or the right, or else to let it read from whatever orientation the rotation gives it?
Just change the setting before doing the other type of text rotation. The difference is easy to spot, so there's no danger of inadvertently adjusting or not adjusting and leaving an incorrect text object.
