J Lucas Posted September 25, 2007 Share Posted September 25, 2007 Does anyone know if the stair tool will draw the dashed stair nosings at the landings? I have not been able to get it to do this. I saw a sample drawing file on the Nemetschek web site where it the dashed stair nosings were drawn at the landing. Quote Link to comment
Guest Posted September 25, 2007 Share Posted September 25, 2007 What version of VW are you using? Quote Link to comment
Guest Posted September 25, 2007 Share Posted September 25, 2007 Select the stair object and go to the Settings button in the Obj Info Palette. Under the General tab, check mark "Draw Dashed Nosing Recess" in the 2D Detail section. Quote Link to comment
J Lucas Posted September 25, 2007 Author Share Posted September 25, 2007 Thanks Katie, I have tried that option. Trouble is, it draws all the dashed nosing recesses on the strair treads but not on the down/riser edge of the landings. Any suggestions? Quote Link to comment
Guest Posted September 25, 2007 Share Posted September 25, 2007 This is what I'm seeing - is it not what you are seeing? Quote Link to comment
Tobias Posted September 25, 2007 Share Posted September 25, 2007 Lucas Turn on "Show Top Tread" in the stair tool. Tobias Quote Link to comment
J Lucas Posted September 25, 2007 Author Share Posted September 25, 2007 Katie: That is what I see if I just draw a streight run. The lack of a nosing at the edge of the landing shows up on a platform L or a platform U. I did some playing around and discovered that although the nosing (at the edge of the landing on the down side) is missing in the stair dialog, plan and 3D, and on the design layer plan view, it shows up in a 3D view on a design layer and in the active section. What gives? Quote Link to comment
Guest Posted September 26, 2007 Share Posted September 26, 2007 Ooh I didn't try an L or U stair. I'll look into this in the morning. Quote Link to comment
Guest Posted September 26, 2007 Share Posted September 26, 2007 I still see the dashed lines. Can you send me a file, please? Quote Link to comment
J Lucas Posted September 28, 2007 Author Share Posted September 28, 2007 The files "Archtiect Eval 01-06" in an introductory tutorial on the NNA web site have a stair symbol in them that has the nosing at the down side of the landing, that is, the nosing is there untill you try to edit it in the stair edit dialog, then the nosing goes away in plan. Quote Link to comment
