James Dawson Design Posted August 7, 2007 Share Posted August 7, 2007 Hi I have a file that contains a stipple and 4 plants (of one type) just above the area that I am working on. These items were not intentionally created and I need to remove them, particularly the plants as they are appearing in the worksheet. The trouble is I cannot select them to delete them. I have had this occur before and as a (not ideal) workaround was able to copy all ?other? items and paste them into a new drawing. In this case VW crashes during the paste process. Any help would be greatly appreciated. james Quote Link to comment
James Dawson Design Posted August 7, 2007 Author Share Posted August 7, 2007 problem solved...thanks julian carr from ozcad solution...select the objects using the bounding box, dont worry if they are not highlighted as selected... then select the menu command Edit/Clear Quote Link to comment
