landscape archiberry Posted July 9, 2007 Share Posted July 9, 2007 Hello, 3-D newbie here. I drew 3 NURB curves, made sure they were closed (connected), then tried to create a surface from the Power Pack. No go: "Surface cannot be created from curve network." I tried composing them into one NURB curve, but got the same message. Is there some requirement I am failing to meet? Quote Link to comment
propstuff at MJLA Posted July 9, 2007 Share Posted July 9, 2007 It sounds like you might be wanting the Loft Surface Tool can you post an image of the curves? N. Quote Link to comment
islandmon Posted July 10, 2007 Share Posted July 10, 2007 To get the NURBS curves to create an interpolated surface you will need to twiddle with the OIP to get the end vertices to mesh properly. Just copy &paste the xyz end point values so that the adjacent curve ends points are congruent. Quote Link to comment
landscape archiberry Posted July 12, 2007 Author Share Posted July 12, 2007 The loft tool...don't know that one yet. Will fiddle. And yes, you're right, islandmon, my vertices WEREN'T meshed after all. Thanks for the help! Quote Link to comment
