symbols
I would search the internet for those. In most cases, you can find a 2D and or 3D model of some format which can be used by VW.
Since VW can import a plethora of file formats, using an already-created symbol is rather simple.
Here's a website that appears to let you enter in the configuration of a gable vent, it will draw it, and create a dwg file of the vent. You can easily import this in to your VW project files.
http://www.steelselect.com/steeltalk/july_2006.htm
HMV -
Can you provide some more detailed information?
What problem are you having while importing?
What version DWG are you importing?
What version of VW are you using?
What OS are you using?
Are you getting an error message? If so, what is the message?
I just tried to merge this with the other post, but I don't think it worked.
Either way -- I need the above questions answers in order to resolve the issue.
You can post the replies to this thread
See if you can go to select all and select something.
Then go to Modify > Edit Symbol
Select all again and look to see if the pen color is set to white.
Is there a specific symbol you imported that you are having a problem with?
Was this from vectordepot.com or another site?
Did you resolve this by changing the pen color?
The objects created are not symbols - they are simply polygons. If you want to use it as a symbol, you'll have to save it as a symbol.
Vectordepot.com has symbols in a native VW format.
If you are looking for 3D objects, you may want to search the internet for .igs or .3ds files. Many of these are free, but some do require either a subscription or purchase as needed.
The gable vent specifically, from the website I posted, can be extruded to create a 3D object and dropped into a wall. It wouldn't take more than a minute to get the data into a 3D object. I would expect you'd spend more time looking for a 3D symbol on the internet than taking the 2d gable vent and converting it to 3d.
