vectornils Posted May 10, 2007 Share Posted May 10, 2007 Hi Everybody! Got a problem with defining the parameters in the doFractal(148.5,210,0,148.5,3); at the end of the script for use in a plugin... the idea is to be able to set object width, height and iteration etc... how do i properly define this parameters?? THANX! PROCEDURE faltFractal; PROCEDURE doFractal(x,ya,yb,breite:REAL; iteration:INTEGER); VAR pageWidth,pageHeight,pageFoldX,xp,xn,ym:REAL; rect1,rect2:HANDLE; BEGIN pageWidth:=297; pageHeight:=210; pageFoldX:=pageWidth/2; PenFore(0,0,65535); moveto(0,0); lineto(pageWidth,0); lineto(pageWidth,pageHeight); lineto(0,pageHeight); lineto(0,0); moveto(pageFoldX,pageHeight); lineto(pageFoldX,0); xp:=x-(breite/2.0); xn:=x+(breite/2.0); ym:=(ya+yb)/2.0; Rect(xp,yb,x,ym); rect1:=LNewObj; SetFPat(rect1,9); Rect(x,yb,xn,ym); rect2:=LNewObj; SetFPat(rect2,70); MoveTo(xp,ym); LineTo(xn,ym); MoveTo(x,ym); LineTo(x,yb); IF(iteration=0) THEN BEGIN MoveTo(x,ym); LineTo(x,ya); MoveTo(xp,yb); LineTo(xp,ym); MoveTo(xn,yb); LineTo(xn,ym); END ELSE BEGIN doFractal(x,ya,ym,breite/2.0,iteration-1); doFractal(xp,ym,yb,breite/2.0,iteration-1); doFractal(xn,ym,yb,breite/2.0,iteration-1); END; END; BEGIN doFractal(148.5,210,0,148.5,3); END; run (faltFractal); Quote Link to comment
SYLVAIN Posted May 11, 2007 Share Posted May 11, 2007 You should create a Point Custom Object and define the variables you want to control as parameters. At the end of the script, doFractal(148.5,210,0,148.5,3); becomes : doFractal(Px,Pya,Pyb,Pbreite,Piteration); Is that what you meant ? Quote Link to comment
