Davis Design Posted February 6, 2000 Share Posted February 6, 2000 I am running vectorworks 8.5.1 on a mac g3; whatshould i set the memory requirements at when i use the 'get info.' for the app. Quote Link to comment
Guest Posted February 7, 2000 Share Posted February 7, 2000 The standard memory setting default is set by Vectorworks. If you are working with larger files and experiencing problems a feasible solution is the set your Minimum size to the Suggested size and make your Preferred size 10 megs or more higher then your minimum ( The distance between this is known as the Partition). This is depending upon what you are doing with the file. Printing, Exporting and Rendering (Renderworks and QuickDraw3d) use memory resources outside of the Vectorworks program, Therefore you should make sure you keep enough resources outside of the program when performing these operations. Otherwise if a large or complex drawing is causing problems then increasing the preferred size to Vectorworks should help. Quote Link to comment
Davis Design Posted February 7, 2000 Author Share Posted February 7, 2000 quote: Originally posted by Mike Swilley: The standard memory setting default is set by Vectorworks. If you are working with larger files and experiencing problems a feasible solution is the set your Minimum size to the Suggested size and make your Preferred size 10 megs or more higher then your minimum ( The distance between this is known as the Partition). This is depending upon what you are doing with the file. Printing, Exporting and Rendering (Renderworks and QuickDraw3d) use memory resources outside of the Vectorworks program, Therefore you should make sure you keep enough resources outside of the program when performing these operations. Otherwise if a large or complex drawing is causing problems then increasing the preferred size to Vectorworks should help. Quote Link to comment
Davis Design Posted February 7, 2000 Author Share Posted February 7, 2000 sorry about that last reply- pressed the wrong button. Anyways, I experience lack of memory errors mainly when I am trying to import image files into a drawing- if there is an external app for this - where is it and how do I adjust memory Quote Link to comment
Guest Posted February 7, 2000 Share Posted February 7, 2000 Importing is actually using preferred memory allocated towards Vectorworks. If you find a large file is giving you some trouble then do the following. (Mac Users only) 1. Exit Vectorworks. 2. Go into Vectorworks folder and Highlight Vectorworks Icon 3. Go to file dropdown menu and select GetInfo, Then Memory. 4. Set your preferred size higher. you may need to experiment depending on the complexity of the file being imported. Quote Link to comment
davelite Posted May 10, 2000 Share Posted May 10, 2000 Ok, how is this done on the PC. I get large drawings and the regens and moving around the program get really slow.. Any ideas? ------------------ David M. Schulman davelite@netunlimited.net Quote Link to comment
