Jac7890 Posted November 9, 2006 Share Posted November 9, 2006 (Hi, this i my first post). When I am in final quality Renderworks in a 3-D perspective view, my windows don't render. Everything else shows color and texture and shadow, but the window is a greyed-out box. Is this normal for the program? I hope not, because that would make Vectorworks pretty crappy. Please help if you can! Quote Link to comment
Ray Libby Posted November 9, 2006 Share Posted November 9, 2006 Welcome! In the help menu open VW help. Do a search on "windows" and "Using Style Classes. It will tell you how to set the glazing parameters. Quote Link to comment
P Retondo Posted November 9, 2006 Share Posted November 9, 2006 If your window is a multiple-unit with mullions, there is a bug in the PIO whereby if the mullions are beyond a certain thickness, they take over the entire window. Check to see if this is your problem. Quote Link to comment
Petri Posted November 9, 2006 Share Posted November 9, 2006 This is one of my standard posts here... One can (and should!) edit the value lists of Plug-Ins. Not even the Spanish Inquisition wants classes called "Style-1", "Style-2" etc. So, go to the VectorScript Plug-In Editor, locate Window (press W to get close quickly), click Edit, Parameters, Values and replace the silly styles with something more appropriate, eg. along these lines: None COL-White COL-Graphite COL-Red COL-Blue MAT-Aluminium-Natural MAT-Aluminium-Bronze MAT-Aluminium-Gold MAT-Timber-Light MAT-Timber-Dark Choose the most likely to be Default. Then you give suitable graphic attributes to classes named in your choices list. Quote Link to comment
