almoors Posted November 3, 2006 Share Posted November 3, 2006 I have been having problems with the trim tools. There are drawings where the trim tool works fine, yet in other drawings it doesn't seem work at all. I'm assuming it is a setting specific to the drawing but have not been unable to find any setting that impacts the functioning of the trim tool. Has anyone had this problem and if so were you able to remendy it. Quote Link to comment
Guest Posted November 3, 2006 Share Posted November 3, 2006 When the trim isn't working, what types of objects are you trying to trim? Quote Link to comment
almoors Posted November 3, 2006 Author Share Posted November 3, 2006 I'm trying to trim intersecting lines. Quote Link to comment
Guest Posted November 3, 2006 Share Posted November 3, 2006 are the two lines on the same layer, and is that layer the active layer or at least set to be modifiable? Quote Link to comment
almoors Posted November 3, 2006 Author Share Posted November 3, 2006 all of the lines are on the same layer and that layer is active. I'm usually trying trim a section of a line intersecting two parallel lines. Quote Link to comment
