bjw Posted October 21, 2006 Share Posted October 21, 2006 OK, so I'm using 12.5 on OS 10.3.9, and Find and Modify just plain doesn't work. The drop down where it gives you the options for the field you've chosen is always blank for example, you can select <light> whose <class> = <(empty)> so is this a bug or is it my copy? anyone else had this? Quote Link to comment
bjw Posted October 24, 2006 Author Share Posted October 24, 2006 yeah...so you know what happens when you import an older file that was poorly made to begin with? all of your lights get labeled 'true' under device type instead of 'light'. And then find and modify doesn't work Quote Link to comment
