panthony Posted September 28, 2006 Share Posted September 28, 2006 In the new 12.5 version it appears that when you select to identify a window as a celestory unit to be shown on plan as a dashed line when above a specified level it shows up on the plan as a solid fill. I have tried everything to remove the fill but all has failed. Another very painful issue with both the window and door pio is that the ID label always defaults to the first class in the class list so each time you need to modify a window or door you must change the ID label class. Anyone found a work-around or corrective action. Thanks Pete A. Quote Link to comment
Guest Posted September 28, 2006 Share Posted September 28, 2006 Hi Pete, I'm looking into the first problem. As far as the second you describe, I can not reproduce this. Is anyone else seeing this? Thanks, Dave Quote Link to comment
