Cloud Hidden Posted August 20, 2002 Share Posted August 20, 2002 Modeling some fairly twisted (not literally--just lotsa compound curves) nurbs surfaces. Too complicated for the shell tool to work. But I still gotta get depth, be/c a wall can't be that thin. So I decide to create another nurbs surface 8" smaller than the first. Works great. Double the work, what with the shapes to loft and the solids to subtract from both now, but at least I can now have an exterior texture that's different from the interior texture, which I wouldn't have had with the shell tool. But at openings, I need to connect the surfaces so you don't see the hollow space between the two layers. And some of the openings are compound curves (a big hole in an ellipsoid, for example). What's the best way to cover this gap cleanly? I don't wanna do anything that loses the different textures int v ext. Thanks. Quote Link to comment
MikeB Posted August 20, 2002 Share Posted August 20, 2002 Where you punched the holes thru the nurbs surfaces, use the extract curve tool to get the perimeter curve of the two holes and then use the loft tool to create a nurbs surface to combine them. Does that make sense? Good Luck Quote Link to comment
Cloud Hidden Posted August 20, 2002 Author Share Posted August 20, 2002 WOW. I'm in the presence of genius. It worked perfectly, and perfectly easy, too. The perfect tool for the job. What an amazing set of capabilities--going from polygon-based CAD to this stuff has been eye-opening, to say the least. Thank you for all the itme you're saving me! So, while we're all here, maybe there's a better way to do another part of the process. I mentioned creating the two surfaces by doing the underlying curves separately and punching the holes separately (subtracting solids). Is there a way to use the first, outer, surface to create the inner one, and avoid all of the duplicate work? I can't just scale, be/c these are odd shapes and a proportionate scale would result in different absolute amounts, but I need equal thickness everywhere. The shell tool is the right idea, but it doesn't handle objects this complex. Quote Link to comment
Matthew Giampapa Posted August 20, 2002 Share Posted August 20, 2002 I think your going about this in the best way. The only other way that seems feasible is some acrobatics involving the stitch and trim commands. The ability to "thicken" a nurbs surface is already on the wish list and should be part of a future major release. Matthew GiampapaNNA Technical Support Quote Link to comment
Cloud Hidden Posted August 20, 2002 Author Share Posted August 20, 2002 >The ability to "thicken" a nurbs surface Be still, my heart... Quote Link to comment
MikeB Posted August 21, 2002 Share Posted August 21, 2002 quote: Originally posted by Cloud Hidden: >The ability to "thicken" a nurbs surfaceBe still, my heart... Man, now that would be really cool! Quote Link to comment
