JHEarcht Posted April 19, 2006 Share Posted April 19, 2006 VW12.0 on Windows XP When I select multiple objects, then change the class in the OIP, the change doesn't stick. So, I have to change them one at a time. Also, when I change an open arrowhead from 20deg to 45deg it doesn't stick. This is an old problem, probably back to VW11. Anybody else having these non-stick problems? Quote Link to comment
JHEarcht Posted April 19, 2006 Author Share Posted April 19, 2006 While I'm griping, I will add that PIOs should be adjustable like other objects. I just added a toilet partition and the partition lines are very heavy. I can't change them by Edit, or Attributes, or OIP. I think I have seen a work-around somewhere, but I'd like more direct control over the display attributes of a PIO. Thanks. Quote Link to comment
JHEarcht Posted April 19, 2006 Author Share Posted April 19, 2006 Regarding the PIO, now I remember the drill: Set up as desired, then convert to symbol, then edit the symbol. but I'd still like to have more control over line weights. Quote Link to comment
Guest Posted April 21, 2006 Share Posted April 21, 2006 Depending on the plug-in object (not specified in your posts), the line weights can be controlled in the plugin object definition such as with windows, doors, stairs, walls, etc. Line weights can still be controlled through class attributes, probably the quicker than editing the symbol for each instance. Quote Link to comment
P Retondo Posted April 22, 2006 Share Posted April 22, 2006 Based on a very quick test with 4 rectangles and 2 dimensions, I don't have a problem changing the class of multiple selected objects. VW12.0.1 Win 2K Quote Link to comment
