Kevin Posted October 14, 2005 Share Posted October 14, 2005 I often rotate objects 45 degrees. What I need is a script that will rotate 45 degrees so that I can assign that to a keyboard shortcut. Does anyone know how to write such a script? I am sure it is a simple one. Quote Link to comment
MullinRJ Posted October 15, 2005 Share Posted October 15, 2005 Hi Kevin, You're right, it is simple. It's a 1 line script: Rotate(45); This will always rotate all selected objects CCW around their collective center. You can have another script to rotate CW: Rotate(-45); If you want to make menu commands instead of scripts, check the VW User's Guide or search this board for instructions on creating a menu command, or ".vsm" object. You can also search the VectorScript List at: http://lists.nemetschek.net/archives/vectorscript-l.html Raymond Quote Link to comment
Kevin Posted October 15, 2005 Author Share Posted October 15, 2005 Thank you, it worked. I don't know how, but I duplicated the structure of a sample script shown in the Manual, and used your script. One day perhaps I will figure out how all of this Vectorscript works. I really admire you guys who know how to do this. Quote Link to comment
