Printing Disaster
jeff
I am working in the theater, and Vectorworks quits when I go to print; it does not get as far as the print window. Indeed, it now quits spontaneously and without any provocation. Restarting does not solve the problem. I am away from home in-theater, and don't have my disks to reinstall or my registration code to run under OS9. I do have high speed internet access. Please advise. I am running a Powerbook G4 667, 768mb RAM, OS 10.2.2. Thanks in advance.
  • 3 weeks later...
What version of VW are you using?
What printer are you using?
You can use the same application under OS 9 - by two ways. You can set the program to launch in classic mode by doing a Cmd I on the application. Checkmark "Launch in Clasic".
Or you can move the application to the root of the hard drive and just create a shortcut on your dekstop for OS 9 to launch it.
You don't need to have it installed twice on one computer to have it launch in OS 9 or 10. I keep everything at the root since I am constantly booting between OS 9 and 10. I only keep one copy of everything.
