royDC Posted March 2, 2005 Share Posted March 2, 2005 I new to vector script. Trying to create some plug-in objects to expedite kitchen design. I am having trouble figuring out how to assign a hatch fill to a rectangle drawn within the script of my plugin. Here is a sample of a cabinet script: PROCEDURE CabinetTest; VAR carc_w : REAL; carc_d : REAL; carc_h : REAL; toe_h : REAL; BEGIN carc_w := PCarcase_Width; carc_d := PCarcase_Depth; NameClass('CarcaseMat'); PenPat(-5); rect(0,carc_d,19mm,0); rect(carc_w-19mm,carc_d,carc_w,0); rect(0,0,carc_w,-20mm); rect(19mm,carc_d-21mm,carc_w-19mm,carc_d-25mm); Moveto(19mm,carc_d); line(carc_w-19mm,0 ); END; RUN(CabinetTest); ___________________ Do I need to use SetVectorFill to assign my hatch? If so, I have no trouble accessing the hatches i have already defined in my document by name, but i can't seem to locate or define a handle for the rectangle i am trying to add a hatch to. Can anyone help here? Seems like this should be very easy . . . Thanks, RoyDC Quote Link to comment
MullinRJ Posted March 2, 2005 Share Posted March 2, 2005 It looks like you are doing this in a PIO. If so, use: BoolResult := GetCustomObjectInfo(objectName, objectHand, recordHand, wallHand); to return a handle to thePIO you are creating. I think myHnd:=FIn3D(objectHand); should return a handle to the first object you created (as numbered below). rect(0,carc_d,19mm,0); { 1 } rect(carc_w-19mm,carc_d,carc_w,0); { 2 } rect(0,0,carc_w,-20mm); { 3 } rect(19mm,carc_d-21mm,carc_w-19mm,carc_d-25mm); { 4 } Moveto(19mm,carc_d); line(carc_w-19mm,0); { 5 } Test myHnd before using it. if (myHnd<>nil) then begin end; Use myHnd:=NextObj(myHnd); to get the second object, etc. If you are in a normal script, use myHnd:=LNewObj; to return a handle to the last object you created (i.e., the line), and use myHnd:=PrevObj(myHnd); to get the second to the last object, etc. These suggestions are off the top of my head, so use with caution. Raymond Quote Link to comment
