scale lineweights script
Dan Kessler
Does anyone have, or know of a script that would allow me to select multiple entities in a drawing and scale their lineweight up or down by a percentage that I specify?
As an example, if I created a drawing at 1/4" scale and decided later that I wanted it to be 1/8"... Is it possible to have a script that would allow me to scale all lineweights by a factor of 0.5 so that the lineweight aren't twice as thick as they should be?
Maybe this is more easily done through Classes? Could it be possible to have a script scale each Classes' lineweight up or down by a factor that I specify?
hello,
I have the following script/command which scales the lineweights of all selected objects. if you want to use classes you need to somehow let vectorscript know which class to search for as well as the scale factor. I like the following because a simple predefined dialog is all thats needed.
PROCEDURE Lineweight;
VAR
pen
:INTEGER;
factor
:REAL;
h:
HANDLE;
BEGIN
factor:=RealDialog('Enter Scale Factor','.5');
h:=LSActlayer;
While h<> NIL DO BEGIN
pen:=getlw(h);
pen:=round(pen*factor);
setlw(h,pen);
h:=PrevSObj(h);
END;
END;
RUN(Lineweight);
i hope this is helpful.
-jason
Walther,
I agree that we could all benefit from Nemetschek including those options within the "scale objects" command and scale tool. More importantly to me, though, is if they would add the scale lineweights option to the layer scale window. Often I find myself drawing something and later changing it's layer's scale.
Dan
[ 02-13-2003, 03:18 PM: Message edited by: Dan Kessler ]
