justin1974 Posted December 22, 2002 Share Posted December 22, 2002 This is my first script attempt, it creates a 2D, 3D pivoting door. Feel free to use the script. Anyone who could comment on the way I'm scripting and give areas for efficiency etc it would be good to get some feed back. For some reason when I put the plugin object into the drawing, a bunch of black control handles appearing in the centre of the page. They are clearly a ghost outline of the object created from the 0,0 coordinates of the page. They can not be selected but are annoying. How can I get rid of them?. PROCEDURE pivotDoor; VAR offset,Clpen,Width,Height,thick,rtpoint1,rtpoint,arcpt:Real; ang,r,g,b:Integer; Arc1,Arc2:Handle; on3d:Boolean; PROCEDURE GreyPen; {gets the rgb from Colour Index} BEGIN; ColorIndextoRGB(52,r,g,b); END; PROCEDURE draw3d; BEGIN; BeginXtrd(0,Height); Rect(-width/2,-thick/2,width/2,thick/2); EndXtrd; Breakwall(0,width,false); dselectall; END; PROCEDURE draw2d; BEGIN; dselectall; Rect(-width/2,-thick/2,width/2,thick/2); Locus(rtpoint,0); Rotatepoint(rtpoint,0,ang); dselectall; Case ang OF 0:message('door closed'); -3600..-1,1..3600: begin; Arc(-width/2,-rtpoint1,(-width/2)+(2*rtpoint1),rtpoint1,180,Ang);{smallarc} Arc1:=Lnewobj; SetLW(arc1,1); SetPenFore(Arc1,r,g,b); SetFpat(arc1,0); Arc(width/2,width/2-rtpoint,-width/2+rtpoint+rtpoint,-width/2+rtpoint,0,ang);{bigarc} Arc2:=Lnewobj; SetLW(arc2,1); SetPenFore(Arc2,r,g,b); SetFpat(arc2,0); dselectall; end; End; END; BEGIN; width:=Pwidth; height:=Pheight; thick:=Pthickness; rtpoint1:=PPivot; ang:=Pangle; rtpoint:=-width/2+rtpoint1; Offset:=Poffset; greypen; Draw2d; Draw3d; Dselectall; End; Run (pivotdoor); Quote Link to comment
Fuge Posted December 25, 2002 Share Posted December 25, 2002 Looks good for your first PIO script. To clean the screen up after the execution of a PIO add SetZoom(GetZoom); after Dselectall; There is also redraw; (For the last created object in VS) and redrawall; (For redrawing all objects on screen), but these commands work well for other types of scripts but not as well for PIO's. Dave Quote Link to comment
