Anita Posted June 11, 2002 Share Posted June 11, 2002 I have applied six drapes of different lengths to a stage, but when I click on the flyover tool, four of them disappear, and two remain. They are invisible until I return to top/plan mode. As far as I can see, I have given them all the same class and attributes. Any ideas? Could it be the fullness or the height being relative to the different lengths? Quote Link to comment
kmoore1 Posted June 11, 2002 Share Posted June 11, 2002 quote: Originally posted by Anita: I have applied six drapes of different lengths to a stage, but when I click on the flyover tool, four of them disappear, and two remain. They are invisible until I return to top/plan mode. As far as I can see, I have given them all the same class and attributes. Any ideas? Could it be the fullness or the height being relative to the different lengths? There is currently a bug with the curtain object that causes it to fail to draw the 3-d component of the curtain when the curtain length exceeds some large multiple of the fullness and the 3-d conversion resolution. You can just take your long curtain runs that are failing in 3-d and draw them as separate shorter curtain segments to work around this problem. Changing the Resolution parameter on the Object info palette for the curtain to a lower number may also help to make the curtain draw in 3-d. [ 06-11-2002: Message edited by: kmoore1 ] Quote Link to comment
avbrendan Posted July 11, 2002 Share Posted July 11, 2002 Was this bug fixed in 9.5.2? If not, when do you expect it to be fixed? Thank you. Quote Link to comment
