Chegs77 Posted March 1, 2002 Share Posted March 1, 2002 Each time Vectorworks is opened on my personal machine (used only by me), the preferences must be reset. Each time it dumps them. Is there something in particular that needs to be done in order for my preferences to be saved each time? Chegs77 Quote Link to comment
Guest Posted March 4, 2002 Share Posted March 4, 2002 It sounds as if you have a corrupted Preferences file. Close VW. Delete the VW Preferences file. Then launch VW. The first time you launch it, you will be prompted to enter in your name, serial number, etc. Then quit the application and the Preferences file should be saved correctly. Go ahead and open the program again. The preferences should be saved. If they are not, make sure you do not have multiple copies of the specific version of VW 9 and the alias you are using matches the correct instance of VW 9.x. Quote Link to comment
