In previous versions, one could select a bunch of objects stacked on top of each other, filled or not, and then hit the command-F keys to cycle through the objects bringing the topmost objects to the front one by one. Now you can't. I liked that alot and miss it. Please let me know if there is a current command sequence to perform said task. Thanks.
BTW - When you select multiple objects you can cycle through them in the object pallette and edit them by hitting the select button which highlights the object. So maybe one could then move that object to the front/back once it's highlighted in the pallette.
David Seibert
7 answers to this question
