propstuff
Split selected objects only
The Split-by-line is a tool I use regularly, but it could be much better.
Currently it will split ALL objects it cuts on any layer (if the "Modify" option is active)The only way to stop this is to lock all the objects you dont want to cut. With a complex drg, if you want to split one thing this is a pain.
What I want is more Modes, with Split Selected Objects as the default.
cheers,
N.
2 answers to this question
It could certainly be better documented, but if you hold down the Alt key on Windows or the Option key on Macs while doing a split by line, only selected objects will be split.
