samps Posted April 17, 2024 Share Posted April 17, 2024 Similar query for other plug-in objects variables: Marionette is very interesting and very powerful, but for now I'm having difficulty using the 'Get Object Variable' to retrieve a massing model 'Floor Count' parameter. An 'Index' is required but I've searched high and low to find a table which provides the index for this param, and is there a way of typing in the field name more directly?? Many thanks in advance Quote Link to comment
Marionette Maven Marissa Farrell Posted April 17, 2024 Marionette Maven Share Posted April 17, 2024 Get Object Variable has a different use-case. In this instance, you want to use the Get Record Field node. Here's a small network that should solve your problem. MassingModelMarionette.vwx Quote Link to comment
samps Posted April 17, 2024 Author Share Posted April 17, 2024 Thank you for the prompt response but apologies, I'm on an older (2020) vw. I've used the 'get Record Field' elsewhere but for this as the field is attached to the object natively I was unsure how to configure it Quote Link to comment
samps Posted April 17, 2024 Author Share Posted April 17, 2024 Got it! Thank you. Using the Object Name 'Massing Model' as the recName and 'NumFloors' as the field value as derived from the worksheet selection criteria Quote Link to comment
