Red Rectangle in Design Layer View
So, found the cause.
The Terrain needed updating even though I had made no changes to it, although I did relocate the whole model to the Origin as it was causing problems with the display, showing loads of lines all over the surfaces. I'm therefore assuming the terrain required updating because of this.
Mike
