Write() command doesn't work
FMA
I have a simple script that intends to read and write into an external text file. The read-part works fine, but I can't get the write function to work, the file always remains unchanged.
PROCEDURE TEST;
VAR
text: ARRAY [1..10000] OF CHAR;
filename: STRING;
writetext: STRING;
BEGIN
filename:= 'C:\test.txt';
writetext:= 'hello';
Open(filename);
Read(text);
message(text[1]);
Write(writetext);
Close(filename);
END;
RUN (TEST);
Is there something wrong with how I use the write() command? Or might it be due to wrong program permission settings?
Hello @FMA,
   I don't believe you can write to your open READ file. You will need to close it first, and reopen it with Rewrite(), or Append(). Then you can write to it. Rewrite() will write over any existing data, and Append() will add to the end of existing data. Don't forget to close it again when you are finished writing.
HTH,
Raymond
