  • 4
Improved Ramp Tool for Building Regulations Compliance
Asemblance
We need to be able to model ramps compliant with building regs (UK; but presumably every country has similar reg's / codes). This would be much easier if:
Essential:
1. The ramp steepness could be set and dispalyed as a 'gradient' rather than 'rise over run' (i.e. 1:20, 1:12)
2. You could add landings at set distances (building reg's require landings every few metres. i.e. a 1:14 ramp requires a landing every 5m)
Nice to have:
3. More options for construction and buildup of ramps; more like stair tool
4. Ideally it would be great to have some smart features that would help you work out the most efficient ramps between two points. But this is more of a nic to have.
  • Like 2
1 answer to this question
