jichan Posted March 14 Share Posted March 14 i'm trying to import the skp file to VW after finish the import process i can see only translucent object my skp file data size is 74,445KB Quote Link to comment
0 Jesse Cogswell Posted March 14 Share Posted March 14 If I had to hazard a guess, I'd say that the SketchUp imported onto a different layer than the active layer, and that your Layer Options are set to Gray / Snap Others since that is the default. Either try to locate the design layer containing the SketchUp model, or go to View - Layer Options - Show / Snap Others. I almost always use Show/Snap Others rather than Show/Snap/Modify Others so that I can work on one thing at a time without accidentally selecting something in the background (selecting a piece of theater architecture while trying to select a lighting a fixture for example), but also know plenty of folks that have the opinion that, if an object is visible, you should be able to select it. Gray / Snap Others can be really great in helping to focus in on one layer at a time since it will gray out everything not on the active layer. 1 Quote Link to comment
0 jichan Posted March 14 Author Share Posted March 14 2 minutes ago, jichan said: Quote Link to comment
0 jichan Posted March 14 Author Share Posted March 14 6 minutes ago, jichan said: this is my orginal skp file i can't see any color of that after import that skp file Quote Link to comment
0 jichan Posted March 15 Author Share Posted March 15 9 hours ago, Jesse Cogswell said: If I had to hazard a guess, I'd say that the SketchUp imported onto a different layer than the active layer, and that your Layer Options are set to Gray / Snap Others since that is the default. Either try to locate the design layer containing the SketchUp model, or go to View - Layer Options - Show / Snap Others. I almost always use Show/Snap Others rather than Show/Snap/Modify Others so that I can work on one thing at a time without accidentally selecting something in the background (selecting a piece of theater architecture while trying to select a lighting a fixture for example), but also know plenty of folks that have the opinion that, if an object is visible, you should be able to select it. Gray / Snap Others can be really great in helping to focus in on one layer at a time since it will gray out everything not on the active layer. Thank you for your help. Thanks to you, I was able to finish the work 1 Quote Link to comment
jichan
4 answers to this question
